need help with headers
RE: need help with headers
You should be able to just pull both of them out the top on a 90. If you can't get the one out the top on the driver side just unbolt the steering arm and pull it out of the way and take the header through the bottom.
you shouldn't have to do that at all. Just take the air intake off on the passenger side, and it should come out without that much effort.
Driver side should come out the top without taking anything off but if it wont just unbolt the h pipe and lower it down. Then unbolt the single bolt on the steering arm and move it out of the way. Then the header will come out the bottom no problem. Oh I see you got the driver side out already, skip the whole driver side part then lol.
