thick wire on the 3g alt
01-19-2007, 10:07 PM
ok so i have one wire left to connect and its the thick one. is it a ground or power? can i just hook it up to the positive side of the battery if its power? thanks
01-19-2007, 10:10 PM
The Rogue Mod
RE: thick wire on the 3g alt
yes, it's power and it goes on the stud on the back of the alt. Make sure you use a in line fusable link. 150 amp.
01-19-2007, 10:12 PM
whats an in line fusable link?
01-19-2007, 10:14 PM
The Rogue Mod
It protechs the circuit in case of a short. The fuse wil blow before electrical damage or fire occurs
01-19-2007, 10:45 PM
ok thanks but the new problem i have now is that i cant put the belt tensioner back on. i cant slide that plate that it has back to the middle. how does it work?
01-19-2007, 10:52 PM
does anyone know how to put the belt tensioner back on?
01-19-2007, 10:53 PM
The Rogue Mod
Why did you take it off?
01-19-2007, 10:55 PM
well i tried to just loosen it up but it wasnt doing anything when i was loosening the bolt. i kept on turning the bolt and the tensioner just popped out.
01-19-2007, 10:58 PM
The Rogue Mod
Ummmm, it's spring loaded, did it come apart? The bolt thru the middle is what holds it in place
01-19-2007, 11:01 PM
the bolt just came out. i tried putting the bolt back in and tightening it while putting pressure on the tensioner and it worked but im not sure if thats how its suppose to go.
