Doing a 5 Lug fox swap and need HELP!!
Do I need new struts? When I try to bolt up the new spindles the strut does not line up like it did on the old spindles. I can make it fit but I want to do this right. Spinles are from a 94 V6.
RE: Doing a 5 Lug fox swap and need HELP!!
ORIGINAL: CompOrangeHatch
So make it fit and then go straight to the alignment shop?
ORIGINAL: PJB
You dont need struts but you will need an alignment.
Im waiting on spindles and calipers that I bought off another forum and then Im going to do the 5 lug conversion on my car.
After adjusting the toe enough to be able to safely drive the car.
Car is a 93. I will get the toe in/out set as best I can then its str8 to the alignment shop. Got the struts to work. Wasnt a problem after all. Just needed to unbolt the strut from the top and bolt it to the spindle and then use jack to jack them back up in.
NEW PROBLEM - What adapter do I need for the passenger side brake line to fit? Can I get a part# if at all possible?
I cant remember the size fitting that you need but i was able to find one at autozone for mine. I just took my new line fittings up there and told them what i needed.
Matt's 95 Stang
10-05-2015 07:16 AM
