rough ride
rough ride
I installed a set of Eibach Pro kit lowering springs in my 1991 gt mustang convertible. They are the specific springs for the convertibles. I also installed new Tokico HP struts and shocks. I installed the Maximum motorsports caster/camber plates.
This ride is way too stiff. The front springs are way too stiff and do not compress enough to allow the struts to dampen the ride when going down the freeway. I chatter over the bumps as opposed to soaking them up with the suspension.
Have others experience this ride quality with the Eibach Pro Kit springs? Has anyone found a way to smooth out the ride and still keep the care lowered. The stance is perfect in the front.
I am going to try lowering the rear more. Right now it is sitting higher than the front and I think it may be putting too much weigh ton the frotn springs. The springs are progressive and may already have the smaller portion (425-530 lb/in) compressed. This could lead to the rough ride.
When I want to take turns hard it does handle a ton better than stock. I want it lowered but want to keep my teeth.
[IMG]local://upfiles/27757/A6DB1148887E4655B480D2A6FB16B9E8.jpg[/IMG]
RE: rough ride
from what ive read about eibach springs,they run about 750lbs in front... which is WAY too stiff. My Ford springs run 650 up front and its almost, but not quite, a harsh ride...
However, if your rear springs are much more than 250lbs... they are WAY too stiff
RE: rough ride
im thinking your car is that way b/c its a vert. I have the pro-kit and you have to remember that your driving a mustang. Also you said you got the hp struts and skocks. I would have gone with the illumia 5 ways. B/c with themy car it sits way lower. B/c i have the springs, but also the new struts and shocks andit made it lower b/c i took the bumpstops out.
RE: rough ride
wow, eibachs and harsh ride doesn't really fit together. if you would've said sportlines i would've said "maybe a little" my buddy has them on his vert, they're stiffer than stock that's for sure, but not that bad. pro-kits aren't as low and are usually very close to a stock feel because of the progressive rate. i run the eibach pro-kits on my focus and aside from much better handling/lowered center of gravity, they didn't affect ride quality.
RE: rough ride
ORIGINAL: HC_CrAzYHoRsE
RE: rough ride
I don't know what gives. The car has no give in the front suspension. When I hit the smallest dip or bump in the road it is translated through the sterring wheel and car. I can watch the front fender bounce as I drive down the highway.What could be making it so stiff? Do the springs take awhile to break in?
