antifreeze in oil pan!!!!
ok when i was taking off my timing cover a little bit of antifreeze leaked into the oil pan. im about to start it but im wondering if i should change the oil now because of this or can i just start it?
RE: antifreeze in oil pan!!!!
i wouldn't engine flush it with antifreeze in it..flush makes the oil really thin as it is..change the oil put some cheap oil in it flush it then use your oil and filter that you desire
ORIGINAL: grabbem88
Change it before you start it up again, use some sort of engine flush (i.e. seafoam or BG, Iuse the engine flush right before every oil change) andrun it, and change it again.
