5 liter fuel injection on a 71 challenger...
My brother has a 71 dodge challenger that he is putting a procharged 440 in. He found that carbed with a procharger the 440 won't make all that much power, and gets like 4 mpg. He read that people can put the 5 liter fuel injection system on a 440 with some modificaiton. I was wondering about what all that he would need, and how big of injectors would he need if he is making 600-700 hp? I know he would need a custom lower manifold, what would you guys recommend for the upper? Also what is the biggest MAF and throttle body you can get. Im guessing 90mm and 80mm.
RE: 5 liter fuel injection on a 71 challenger...
You doubt you can do it since I'm pretty sure that 440's have different firing order. It wouldn't run right even if you switched the injector harness around. I would look into a standalone efi system. Check on summit they sell a couple of them.
ORIGINAL: ZachW04Stang
www.megasquirt.info
www.diyautotune.com
ORIGINAL: 94ford5liter
Yea I saw those they are really expensive lol.
he needs to install a 6 pk intake and run 3 throttle bodies
if theres a will there will be a way, when it gets it done i would like to
see it, when i get time to get back to my 70 barracuda it has a 440
mag in it and a efi set up would be great !
there are lots of options if a person understands the electronics well enough
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
