In-line vs. In-tank Fuel Pumps
Obviously, after all the mods I need to boost the fuel pump a few lph. I have been looking at both in-tank pumps and in-line pumps and can't decide which one to go with. I was hoping to hear the pros and cons of both styles. Also hoping to hear from people who have done one or the other to see if they ran into any problems with their setup.
Thanx
Thanx
RE: In-line vs. In-tank Fuel Pumps
i cant tell you the pros or cons really but i can tell you that i run both on my car. i have a 255lph pump in the tank and a t-rex pump in line. the inline was easier to install because i didnt have to drop the tank but it wasnt a plug and play deal like the intank pump was. i had to make a mount for it, tap into the wire for the intank pump and wire up a relay.
In the end, I'll probably end up going with both as well. Upgrading my injectors, pump, and MAF. I may also put on some wideband O2 sensors as well so I can install an AF Ratio gauge.
ORIGINAL: Glasersil
Are you running the stock fuel pump?
mrappe
09-26-2015 10:16 AM
