Springs
what is the differnts between progressive springs and specific spring
RE: Springs
I've never heard the term specific spring. Do you mean Linear?
RE: Springs
BBK makes specifec rate lowering springs and Progressive rate lowering spring and i have seen these terms used on other companys and i would like the differnt IF anyone know please respond
RE: Springs
ORIGINAL: Yngvar what is the differnts between progressive springs and specific spring |
RE: Springs
RE: Springs
so specific is like linear rate, right?
RE: Springs
ORIGINAL: OnyxCobra so specific is like linear rate, right? |
RE: Springs
which one will give you better performance
RE: Springs
Specific and Linear Rate springs are the same thing, they both will compress at the same rate throughout the travel of the compression or rebound, Progressive Rate springs give more resistance as the spring is compressed (non-linear or exponential) the spring rate is dependant on the compression distance...
RE: Springs
+1, yep. Thats it as far asI know.......
