smog pump delete
smog pump delete
i just deleted my smog pump, i was wondering what i should do to the block..there i two blots in the back of the block. how would plug those up? just put the bolts back in? and would this effect my compueter at all?
RE: smog pump delete
all that tube does is pump fresh air into the cats
take the cats off.. they rob power
i just went from 4 cats to 0 cats and i noticed some throttle response
not only that but its sounds so badass... if you want your car to bark take em off haha
So i guess I can take out the thing the vacuum line plugs into plug the vacuum line and let the tube stay there still plugged into the two pipes in the back. if that true that sounds pretty easy
