help with good coilover susp
Old 01-23-2007, 07:53 PM
coopertrooper
coopertrooper's Avatar
Default help with good coilover susp
Fit like?
I'm lookin' for a real good set of coilovers for my 90 LX 5.0. I use it as a daily driver to get me to and fromwork, down the boozer and up to the slopes. Ido howeveruse iton the track fairly oftenwhen ever theopportunity presents its selfany ideas on a good brand and model lads?
Thanks very much!
coopertrooper is offline
Old 01-23-2007, 08:09 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: help with good coilover susp
coilovers make LOTS of noise, and you can get a better ride from OEM style equipment
AdderMk2 is offline
Old 01-23-2007, 08:12 PM
coopertrooper
Okay
could you elaborate any on the OEM like equipment i should be lookin' for?
Thanks man
Old 01-23-2007, 08:13 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
sounds like you can't answer the guyfigures
dude a low price set up from UPR products with do ya just fine..but remember you will need camber plates with the coil overs...
2 kwik is offline
Old 01-23-2007, 08:14 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 2 kwik
preferable MM or hotchkis... 4 bolt camber caster plates are a must with coilovers.... but id prefer not to sacrifice my ride comfort and stick to OEM style shocks and struts with a nice set of springs.
Besides... look at how many people bitch about the weird noises their coilovers make!
AdderMk2 is offline
Old 01-23-2007, 08:16 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
again..it's a 90 lx which DOESN'T HAVE 4 BOLTS FOR CAMBER PLATES....
2 kwik is offline
Old 01-23-2007, 08:17 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 2 kwik
point noted... forgot it was a fox
AdderMk2 is offline
Old 01-23-2007, 08:18 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
wow vfast aka 2 kwikhas good information
2 kwik is offline
Old 01-23-2007, 08:25 PM
coopertrooper
Right sweet, but i'm not really bothered about squeeks klunks and rattles (unless there comin from the engine bay! lol) so coilovers might actuly be the way to go. Also what about sway bars, tie rods, upper/lower control arms and camber adjustment? obviously when it goes lower the camber will be knocked out of whack.
Really appreciate the help! I'm fairly layin' it on yahere chaps.. soz!
Old 01-23-2007, 08:29 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
it would help to see what the hell your doing..because what you said the car is for and what your looking at isn't going to work well...if your looking for something to handle better then some 17 rims,poly bushings,larger sway bars,adjustable shocks,poly bushing..you can go futher into it
2 kwik is offline
Quick Reply: help with good coilover susp
