clutch
RE: clutch
to get the shifter off? unscrew the shifter ****, remove the trim by prying it up, then remove the four screws that hold the rubber splash thing on with and 8mm wrench. then the shifter is held on by four 1/2 inch bolts, remove them and pull it out. when u put it back be careful to not strip the bolts that hold the shifter in. mine did because it been off so many times and i had to helicoil it.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
