UPDATED...SAWED THE M'FER IN 2 <PICS>
RE: I STARTED...SAWED THE M'FER IN 2 <PICS>
have you checked out TMossporting.com he goes into porting the lower, and similar stuff, dont know if that would be of much help but it was just to throw out there.
I have a stage 3 port job on my intake, the t/b opening was ported too, I guess the lower it what has the stage 3 job done, lastn owner told me this. He had it done at Anderson Ford Motorsprorts from around where i live, Somewhere around Springfield IL
ORIGINAL: CrazyCobraSpeed
ive heard that shops can do a port job... i was goin to get my heads ported to get ride of my bottle neck heads... i figured my cobra intake would need to be ported next... would a shop more than likely do more htan u have done or is a very basic porting??? also were do u cut it at... i have a cobra intake like i said and hte only reason i and porting it out and not gettin an aftermarket one is i wanna keep the stock look... kinda sleeper
http://www.tmossporting.com/ Look there, is is a good starting poiont and will give you an idea....the cobra intake is different than my stock intake (same as the he is working on)
ORIGINAL: Red FIVE O
Here are some pictures of my progress....the line drawn on is where I cut it. I already started finishing/cleaning up the welds.
Here are a couple of the lower where I welded it at. I still have tons of work to do to that(welds look like poo)
ORIGINAL: turbosha
only if you get the #'s you wanted !sand blast everything clean then clearcoat
ORIGINAL: notch5oh
the welds may not look perfect, but most people cant even weld aluminum
are you gonna clean up all the factory casting marks and #'s?
