turn signal switch
turn signal switch
i bought an 86 mustang gt about a week ago maybe i got it for $2000 with only 90k miles on it with two slight problems the turn signal switch only works in one direction and yet i have to hold it down in order for the blinker to stay on. is the switch easy to install i did a search but found nothing.i also have an issue with passenger side window not working it wont go up[:@] what can be the problem there.?
RE: turn signal switch
[*]Disconnect battery ground cable.[*]On models with tilt column, remove upper extension shroud by unsnapping shroud retaining clips at the 9 o'clock position.[*]Remove five attaching screws, then separate and remove two trim shroud halves.[*]Grasp turn signal switch lever by grasping and using a twisting pulling motion while pulling lever outward.[*]Peel back foam shield from turn signal switch, then disconnect two turn signal switch electrical connectors.[*]Remove two screws attaching turn signal switch to lock housing, then disengage switch from housing and remove.[*]Reverse procedure to install.[/ol]
TfcCDR
09-14-2015 12:08 PM
