Cams and RR's
Old 01-24-2007, 09:45 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: Thoughts on camshafts?
yes...these engines are crying out for a dual pattern cam......don't get me wrong if it's just a few ponies you want with stock heads..thier ok..
2 kwik is offline
Old 01-25-2007, 04:48 PM
90Lxstanger
90Lxstanger's Avatar
ORIGINAL: 90Lxstanger
Yeah, i have a stock cam, and 1.7 RR's, so i was told that thats combo will make the stock cam like a B303, i was wondering how true? And i have heard thatthe Bcam is a flop?, but my car runs smooth and good power, and also would that hurt the computer when running a speed density system?,cuz it doesnt seem to cause any problems.i dont know the lobe center or what the vaccum is(stock is 115).
cam specs for FRPP B303-
1985-95 302 with Roller Tappet Cam
(1)(2)
Hydraulic Roller Tappet
Max torque3300
Max BHP 5100
Duration 284°
Duration 284°
LIft Intake 0.480"
Lift Exaust 0.480"
so 0.473 isnt that far from .480(b303) and .498(e303). looks to me that .473 is closer to .480. so i would think that its closer to a B cam-(lift wise) than it is an E, i dont know about the duration, but itsseems to becloser to a b303-as for lift.Any others thoughts are welcome
90Lxstanger is offline
Old 01-28-2007, 03:34 PM
90Lxstanger
Thread's a few days old...... just wondering what anyone else thinks. or if they have duration numbers too
Thanks again
Old 01-28-2007, 04:19 PM
FullAuto
FullAuto's Avatar
The stock cam is closer to an E cam than a B cam when comparing duration. You'll notice the duration difference before you'll notice the difference in lift.
Who cares anyway? They're all junk.
FullAuto is offline
Old 01-28-2007, 04:49 PM
Joel5.0
Joel5.0's Avatar
Cam duration is not affected by the rockers, the cam lobes are not "modified" in any way.....stock cam lift with 1.6R's = .444"...with 1.7 = .472"........if your engine is a '86-'88 it would have 266° Int/266° Exh........'89+ is 276° Int/266° Exh.
SD "friendly" cams are limited and it doesn't mean they will run like stock, they usually will run on the rich side due to the impact in engine vacuum production @idle and part throttle...........
Joel5.0 is offline
Old 01-28-2007, 04:58 PM
OnyxCobra
OnyxCobra's Avatar
I always thought the duration might be slightly more with a 1.7 rocker just b/c of the fact that if the valve has to open farther, it seems to me like the duration would have to be a little more. [sm=feedback.gif]
OnyxCobra is offline
Old 01-28-2007, 05:22 PM
FullAuto
FullAuto's Avatar
ORIGINAL: OnyxCobra
You're asuming that the valve must open and close at the same rate. Only then would it need more time to reach a higher lift. If you open and close the valve faster, you can reach a higher lift in the same time.
FullAuto is offline
Old 01-28-2007, 05:28 PM
OnyxCobra
OnyxCobra's Avatar
so is that what happens? the valves open faster with 1.7s?
Old 01-28-2007, 06:15 PM
Joel5.0
Joel5.0's Avatar
Maybe this might help......
Joel5.0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Cams and RR's
