Cams and RR's
Cams and RR's
Yeah, i have a stock cam, and 1.7 RR's, so i was told that thats combo will make the stock camalmost likea B303, i was wondering how true? And i have heard thatthe Bcam is a flop?, but my car runs smooth and good power, and also would that hurt the computer when running a speed density system?,cuz it doesnt seem to cause any problems.i dont know the lobe center or what the vaccum is(stock is 115).
cam specs for FRPP B303-
1985-95 302 with Roller Tappet Cam
(1)(2)
Hydraulic Roller Tappet
Max torque3300
Max BHP 5100
Duration 284°
Duration 284°
LIft Intake 0.480"
Lift Exaust 0.480"
(1)(2)
Max torque3300
Max BHP 5100
Duration 284°
Duration 284°
LIft Intake 0.480"
Lift Exaust 0.480"
RE: Thoughts on camshafts?
Stock cam with 1.7s is smaller than a bcam. It would not run, idle to well on speed density. If someone has a speed density car you need to convert to mass air eventually, so just put it in your budget. (I did)
Well mines is a SD system, the last owner of my car said he got it too run better with that setup, he converted the car from a 4 banger to a V8. He did i great job on everything, changed over wiring harness, and put an A7AO7 computer in it. I was wondering if anyone knew what the duration and lift would be with 1.7 rr's. i know ive seen it before but i cant seem to find it again. if anyone knows, thanks
I dont remember what the lift is on the stock cam, but I know that 1.7s take up the lift quite a bit. On my car with the E303 and 1.7s it is at 528 lift. Compared to only 498 lift with 1.6.
ORIGINAL: 2 kwik
about .472 or so....
i found a book that says a 93 cobra cam has .4797 lift with 0 lash. and a bcam .480has with .284 duration it didnt say the duration of a cobra cam .so unless you have a cam from a 1993 cobra it nothing like a b cam. and 2 kwik why do you say the alph. cams are no good ? cause there single pattern ?
