What heads should i go with on my set up afr 185's or 205's
i have a 1990 gt with 347 stroker, vortech v1 supercharger 8lbs of boost, trick flow track heat intake, long tubes, forged internals, just wondering what heads be best for my set up thanks guys.
RE: What heads should i go with on my set up afr 185's or 205's
Why only AFR's? If I had to pick just between the 185's and 205's I would go with the 205's.... but you can get heads that will perform the same if not better for less cash.
Ok I lied. I would go with Canfields 192 head.... it flows a little less than the 205 and its about 400-500 dollars cheaper. Plus those heads might work a little better for street use.
Not sure.... thats something you would have to call Canfield about. And you shouldnt be using those headers anyway. You should definetly step up toa 1 3/4 without a doubt. Get the canfields and with the money that you are saving from not buying the AFR's get yourself a nice set of 1 3/4 longtubes.
i had afr 185's that i sold on here and upgraded to 205's. I had the 185's maxed yes i could have ported then and all that but with the price i got for my 185's and a few hundred i got 205's and i dont have to port them. (Yet)
