My 95 GT has the readend shake
I just bought a 95 GT and I'm slowly getting everything to decent drivability. I changed front rotors/pads and it stops fine but at cruise speed it wobbles slightlyand shakes in the back end and even the steering column a little, I've got 225/60R16's and stock rims. Got any suggestions? Should I jus change the back discs too or is it something more serious? Please Help!
did you have the rotors turned?????? look at the driveshaft some times the weight will fall off but it's rare or a dent...check tires may have a belt seperating in tire? bent rim?..lose tire?brushing may be wore out..check the list let me know Id like to know hope it helps
Sounds like a tire with to much runout, a bent rim or both. Have the tires balanced and make sure you take it to a shop that has the capabilities to "road force" balance the tire. If everything checks out have it aligned and make sure they check your rear thrust angle.
