Rear-END Vibratrion?!?!?
RE: Rear-END Vibratrion?!?!?
At first when i saw this thread i was like [][][][]
but then i read it and was like
haha...but seriously...check your tire pressure, might be that...could be that one of your tires is loose....check lug nuts
Along with pressure, check the tires for any unusual wear that could indicate belt seperation, and look at the wheels to see if you may have thrown a balancing weight. Also, did you recently have to lock up the rear tires in a stop? That could flat spot them and create a vibration. Also, although very rare, I have seen a driveshaft throw a wieght to cause a vibration.
Good Luck
Good Luck
thanks for the replies guys....turns out: Spider gears needed replacing and I have a set of Strange axles coming ...oh well at least the rear shall be pretty damn bullet proof now...or soon anyways..
StupidTodd
11-08-2005 03:18 AM
