Oil filter?
Old 01-25-2007, 08:31 PM
88blackgt
88blackgt's Avatar
Default RE: Oil filter?
no motorcraft at walmart doesnt equal fram
88blackgt is offline
Old 01-25-2007, 08:34 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you know putting a magnet on the oil filter is cheaper..also use 1 on the bottom of the oil pan and oil plugs as well
ORIGINAL: mattdel
yah my magnetic oil filter requires the use of the SSP filter
2 kwik is offline
Old 01-25-2007, 08:37 PM
mattdel
mattdel's Avatar
yah but this thing is beefy. weighs like 3 pounds. oil actually goes through it instead of waiting for the oil to come in contact with a magnet.
mattdel is offline
Old 01-25-2007, 08:40 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
have you ever had one cut open to check it out?
2 kwik is offline
Old 01-25-2007, 08:42 PM
Lx88Notch
Lx88Notch's Avatar
when putting a magnet on the bottom of the pan, what method do you use to ensure it all (debris) will come out when draining, i wanted to do that but was worried about effectively getting any shavings, etc out without it just sitting at the bottom and running thru again after the change
Lx88Notch is offline
Old 01-25-2007, 08:44 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
I remove the magnet..drain oil...pour in 1/2qt of clean oil let drain...
2 kwik is offline
mattdel
mattdel's Avatar
you can buy drain plugs with magnet tips, but like i said, the metal must be close enough for the magnet to work. with the filter magnet i have, you have the oil being pumped through the magnet, affectively removing metal from the pressurized oil
mattdel is offline
Old 01-25-2007, 08:46 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
wouldn't it be trapped in the filter infront of the magnet to secure it?...when you get an old one would you send it to me I'd like to cut one open to look at it
2 kwik is offline
Old 01-25-2007, 08:47 PM
Lx88Notch
Lx88Notch's Avatar
cool, ill have to try this when i do my next change. would "cranking" it over once also push the stuff at the bottom better or no. cause in my 01 mustang i would turn it over to make sure all the oil was out, by turn it over, i dont mean started, as im sure you know what i am trying to explain in a million words.
Old 01-25-2007, 08:48 PM
mattdel
mattdel's Avatar
no, it screws onto the filter adapter on the block, and the SSP filter screws onto it.
mattdel is offline
Quick Reply: Oil filter?
