Spark Plug Question
#21
RE: Spark Plug Question
ORIGINAL: mattdel
i'm telling you, get rid of the platinums. the EEC-IV ignition system is not compatible with platinum plugs. period.
Your EVP sensor is probably showing EGR movement when the computer knows that it shouldn't be moving. A trick to cure this, remove the sensor, and on a grinding wheel or with a file, shave a millimeter or two off of the pintle. this will allow the pintle to extend fully and not be blocked by carbon deposits, thus providing accurate readings again.
#23
mattdel i had a shop run my codes for free and the only thing that came up was something due with the ERG. The guy checked it out and said the erg sensor was broken ie smashed, but this should not be my problem.
