83 belhousing issue.
i dropped a 351w in my mustang gt with the stock belhousing/tranny and a 10.5 cobra clutch kit and 28oz flywheel. the motor was a dud(although we had it running for a while(crack in the block causing coolant in the oil))so we pulled it out (covered by warrenty). we got the new motor built and stuff but theres a problem, we tookthe tranny off theold motorto find a deep groove from the clutch cut into the bel housing(we heard it while the car was running with the old motor). Anyone have an idea????
RE: 83 belhousing issue.
ORIGINAL: Force4
ORIGINAL: Fosters82GT
Count the teeth on the flywheel. There's probably 164 teeth if it's hitting the bellhousing and it should have 157. You'll have to specifically look for a 157 tooth flywheel with 28 oz balance that will accommodate a 10.5" clutch with metric thread holes for the pressure plate - not all 157 tooth flywheels will accommodate a 10.5" clutch. Good luck!
I should have been clearer in my description. Actually the pressure plate rubs on the bellhousing and not the flywheel. The car originally had a 10" clutch and we upgraded it to a 10.5" king cobra clutchwith a 157 tooth metric bolt 28oz flywheel.Was the 86 or later bellhousing changed for the larger clutch? This may be why I am having a problem.
wellwhat year was 351 w is it after 82 where it was 50 oz and ya put a 28 oz on it...or was it older and a 28 oz too///and a t-5 needs a 10 splin,157 tooth 10 1/2 inch clutch///b4 82 wwill needs a 28 oz flywheel on a older 351////a newer 351 will need a 50 oz..//i know its like this on a 302/and pretty sure om a 351//167 tooth wont work
or ya alignment was off///did ya torq down bolt to spec..did ya use dowl pins too
ORIGINAL: hellas85stang
it was ONLY the 5.0HO that swapped to a 50oz imbalance
http://cgi.ebay.com/ebaymotors/86-93...75075499QQrdZ1
AmericanMuscle4.6GT
11-10-2015 02:06 PM
