PRO5.0
PRO5.0
Got my new PRO50 shifter in! Man what a difference, it doesn't even feel like the same transmission. I had to get used to it at first cuz it would shift faster than i could kick the clutch and i was grinding gears! Definetly worth the money.
RE: PRO5.0
Its the same as any other short throw, get the plastic outta the way, unbolt the 4 bolts, and pry up on the shifter to get it out. Take that little plastic ball off the stocker, swap it onto the pro50 and put a bead of RTV around the base. bolt it down and adjust the stops. It should come with instructions.
RE: PRO5.0
ORIGINAL: WhiteFoxGT
