rear control arms
RE: rear control arms
ORIGINAL: dimebag
theres a sticky about the team mf thing over in the street/strip section... check it out.
and thanks pro. there actually cheaper then what ive seen, lol. i think thats what ill go with...
whats ur suspension set up pro? and how is it for ya?
Check this link out.. same control arms with subframes for not much more money.
the upr spring pearch on the lower control arm seem's small when I installed them on my stang. and yes adjustable shock are the way to go if your going dd and some track time. couple turns and you set the shocks the way you want. soft for drag, more stiff for street. lol
ORIGINAL: PRO50SC
The ones I posted, that's it. That's why I'm thinkin about some adjustables. I wanna dial in my pinion angle!
5.0stanger, how do you like the lowers. I was lookin at those actually. Are they noisey at all b/c of the ball mount in the front?
ORIGINAL: dimebag
ORIGINAL: frdmstng1986GT
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
ORIGINAL: dimebag
had a bend in them and the ends were capped andwelded up. Those just don't look to be the nicest.
I think I would get different subframes.
I'd go with a tubular design from BMR or MM for your upper and lower ca's. If you're looking for an ok cheap setup then that ebay kit would work minus those sub connectors.
[IMG]local://upfiles/4191/AD50FC18F0E740289DDD4046B1E29291.jpg[/IMG]
