Pinstripe Removal
RE: Pinstripe Removal
should be over the clearcoat, i've used a pinstripe eraser that mounts to ant 3/8 drill works perfect and wont harm the finish. i think you can only get it at body shop supply stores.i wouldnt try oven cleaner tho.
Usually pinstriping (unless painted on) is put on after the clearcoat b/c its just vynal, with a little heat it should peel right off. However I was told 89 Mustangs didnt have clearcoat, anyone know if thats true?
ORIGINAL: turbosha
hmm well i prolly should of waited to see what u guys said but i used oven cleaner on the stripe for 45 minutes on a small section and all it did was fade it. where can i buy one of these pinstripe erasers?
