doing the gt to lx ground fx conversion need help
RE: doing the gt to lx ground fx conversion need help
The rocker moldings (ground effects) are held on by a long metal strip and some clips that are riveted to the body. There will be holes left when you remove them.
+1
There will be holes on the bottom from the metal strips that hold on the GT sideskirts. The fenders moldings are different along with the door moldings. I never thought about using fishing line to take them off but it sounds like it might work. Heating them up with a blowdryer will also make it TONS easier, it will heat up the glue and loosen it. The wing is also different along the with front/rear bumper obviously. And dont forget, if you have an aftermarket exhaust designed for a GT its going to look retarted because your exhaust is going to hang like 5" lower than your rear bumper.
jwog666
12-27-2021 08:09 PM
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
