roller rocker arms?
roller rocker arms?
when i bought the mustang the guy i bought it from gave me ford racing roller rocker armsthat he never installed. iv tried looking them up but i cant figure out what they do performance wise. can someone help me out
RE: roller rocker arms?
a little bit...if you look i know the 1.6s that i bought had1.6 stamped on with some other bs...but the 1.7 would create a higher lift that could help you a little more on the top end if the motor is set up for them
the ratio should be stamped on them.
even if you have the 1.6 you can still pick up a couple of hp by putting them on because they create less friction then the stock rocker arms
