windage
Old 01-30-2007, 10:15 PM
stanglx2002
stanglx2002's Avatar
Default windage
Are they worth it? Also if they are what is the best brand to get?? I have read that the Canton one is the best because it is screened unlike the others that are louvered. Also do you have to get a crankscraper??
stanglx2002 is offline
Old 01-30-2007, 11:31 PM
silver91gt
silver91gt's Avatar
Default RE: windage
I would also like to know
silver91gt is offline
Old 01-31-2007, 12:18 AM
2oo5stang
2oo5stang's Avatar
Default RE: windage
they all do about the same, i like canton. Their goal is to make the oil that is slinging in the pan to stay off the crank to stop the parasitic lost due to oil clinging to the crank. One 5.0 trick at the track is to drain your oil till you have about 2-3 quarts left in your car. that's one way to get the oil from not hanging onto the crank, but for track only. I've seen advertised to give about 10hp, maybe. is it worth pulling your motor to do it, i would say no. if the motor is out already, then i probably would.
2oo5stang is offline
Old 01-31-2007, 12:41 AM
musclemustang94
musclemustang94's Avatar
Default RE: windage
One other trick i know is too polish the lifter valley till its smooth and paint it with this stuff called GLYPTOL (spelling). It makes the valley super smooth and all the oil returns to the pan faster. This lets you run less oil in your engine with out problems.
musclemustang94 is offline
Old 01-31-2007, 02:25 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: windage
i put one on my new motor. cant say if it works really well cause the motor in in my garage and not my car. not sure how they would bolt on because my windage tray bolts to the main stud girdle
luckythirteen13 is offline
Old 01-31-2007, 05:46 PM
stanglx2002
Default RE: windage
so can you just get the tray and not the crankscraper or do you need both?
Old 01-31-2007, 11:55 PM
stanglx2002
Default RE: windage
is the windage worth it or not?
Old 02-01-2007, 12:22 AM
turbosha
turbosha's Avatar
Default RE: windage
they say its worth 10 hp and keeping the air out of the oil is piceless. dss has a nice windage tray that bolts to there main support system. think of it like this , the crank is whipping around like a blender and the oil is like ice cream.......... hang on i want a shake !
turbosha is offline
racer02GTstang
02-12-2007 02:57 PM
SCHOONER
08-28-2006 04:00 AM
slickman
06-18-2006 01:19 AM
pitman86gt
06-04-2006 02:59 AM
schwindty
12-05-2005 06:35 PM
Quick Reply: windage
