IS THICK OIL BETTER FOR BIGGER ENGINES
RE: WHATS THE PROPER WEIGHT FOR OIL
don't use a oil that heavy since it's getting cooler.....the 10-40 is heavy enogh unless you have a high pressure or high volume oil pump..you have increase wear at start up..and isn't that your thinking to help reduce wear?....your best protection is sythed. 10-40 summer 10/30 winter and a oil primer this would reduce wear in the 30-50% range....you'll never see detroit do it because they need to sell cars
Use 5w or 10w30 unless your burning some oil, then go 10w40, NEVER use 20w50 in any modern automobile engine unless its on its last leg anyways. Newer cars usually use 5w20. Oil weight is determined by both engine bearing clearances and operation temperature. The lower weight oil you use the easier the car is to start, the better gas mileage you get, but at the expense of lower oil pressure if your bearing clearances are too loose and burning oil if your rings are worn.
no it's a pump to prime the engine of oil to a pre set psi normally like 15 psi...same thing when you fire up a new engine using a drill to move the oil pump this just uses a electric pump
VFast......what about Rotella 15-40. all my friends told me to use it, and they all use it in their stangs. they say its the best oil theyve ever used.....??? good ? bad ?? ever used it ??
