351 windsor
351 windsor
i have the opportunity to buy a 351w from a friend of mine for 150 bucks. it does run but it needs a rebuild because it has 150000 miles on it. i popped the valva cover off and it looks clean. as of right now im dropping the 302 in my car but eventually i would like to put a 351 in it (next winter possibly). should i buy it now and start the rebuild on the engine this summer?
RE: 351 windsor
If the block passes a compression test, then it could have some miles left in it...
I would at least strip it down the short block and inspect the bores for wear, and check the main bearings.
jason
jason
RE: 351 windsor
ORIGINAL: tinman
352W swap into a Mustang can get sort of expensive.
You at least.............
Oil pan
Headers
engine mounts OR a hood...........
Oil pan
Headers
bradleyb
11-27-2015 07:50 PM
Mustangs of Illinois
08-22-2015 10:00 PM
