Quick fuel pump wiring question..
RE: Quick fuel pump wiring question..
so far every diagram I've found basically shows just a power wire to the fuel pump, and a ground coming off of the pump. Will the pump run with those basics or is there more involved? I'm not even talking factory function, just power source to it, and a ground will the fuel pump function?
do happen to know off hand which colors are for the fuel level and which is the pump? And for the pump is it just posi and ground? and thne I'm guessing the sender is posi and signal back to the gauge or somethin?
I think that the Pink one is power for the pump, & one of the Blacks is ground for the pump. But there are 2 blacks. If all you do is cut the pink one and provide power to it, it will work. Just dont cut a black.
Evil is right. The pink/blue striped wire is the power for the fuel pump. I can't remember if the black/ground side is actually a black wire. For some reason I'm thinking a light green/green stripe but I can't confirm that while I'm at work. My wiring diagrams are at home.
ok thanks guys,hopefully I can get this taken care of tonight...gettin the car towed back to my house so I can work on it in the garage [:@]another 40$ I didn't wanna spend.
TfcCDR
09-14-2015 12:08 PM
