Anti-freeze leaking behind my water neck
Old 02-02-2007, 02:24 AM
JH23
JH23's Avatar
Default Anti-freeze leaking behind my water neck
any idea where it could be coming from ?...radiator isnt low...but there is a little anti freeze right behind the water neck...if need be i can take a picture to let you see where its puddled up at.
JH23 is offline
Old 02-02-2007, 02:59 AM
nmerrill
nmerrill's Avatar
Default RE: Anti-freeze leaking behind my water neck
did you recently change something? Mine did that after i changed the thermo., and it ended up being that the thermo. was slightly out of its place and caused a little leak.
nmerrill is offline
Old 02-02-2007, 03:00 AM
JH23
JH23's Avatar
havent changed the tstat yet but i am tomorrow...but i just went out and checked my intake bolts and the bolt that was closest to the puddle was loose....so i guess with only 3,000 miles things are starting to wear and loosen up a little...i'll check them all tomorrow and hopefully thats all it is
thanks merrill
JH23 is offline
Old 02-02-2007, 04:31 AM
w8less
w8less's Avatar
when u change the t-stat make sure u use the gasket and some gasket sealant.
when i changed mine it kept leaking
w8less is offline
Old 02-02-2007, 04:36 AM
JH23
JH23's Avatar
got cha there jasper...i'm gone use some doo doo to make sure the heffer dont leak...aggravating as heck man lol
JH23 is offline
Old 02-02-2007, 04:38 AM
w8less
w8less's Avatar
yep it left me stranded at work twice. just think about changing it on freshly paved black top in 103 degree weather LOTS OF FUN
w8less is offline
Old 02-02-2007, 04:59 AM
JH23
JH23's Avatar
oh hoss that would BLOW lol....REAL bad.....i'm putting in a new 180,its s'posedly has a 180 but man going down the hwy my temp reaches as high as 150....yes...as high as 150 lol....and its running REALLY rich...so i'm hoping thats some of the problem there
JH23 is offline
Old 02-02-2007, 05:03 AM
w8less
w8less's Avatar
thats what i had was a 180 but mine kept sticking thats why i changed it. add some tiiming to it
w8less is offline
Old 02-02-2007, 05:25 AM
JH23
JH23's Avatar
adding timing does what for it ?...you'll have to excuse all my questions...i'm a person in learning lol
JH23 is offline
Old 02-02-2007, 05:40 AM
w8less
w8less's Avatar
when my car was running rich we added timing to it to lean it out. evrey motor is different. in ur case it could jsut be a tempory solution. whats ur timing set at now?
w8less is offline
Quick Reply: Anti-freeze leaking behind my water neck
