Reliability of a 408 stroker.
RE: Reliability of a 408 stroker.
ORIGINAL: Redrider69
I wanted to go with the 427, but i did some research and it seemed like they had a lot of problems with it.
ORIGINAL: 2 kwik
the reason for this is if your going to put out the cash for a 427 with it's potentail power you want a good block...because who wants to build a 450hp 427 cu in engine????
With the 408, Afr 185's, Trick Flow Intake, good cam, pulleys, long tube headers with good h pipe and mufflers, good fuel system, and a 75mm tb and 90mm maf and all those other little things like cold air intake, fidanza fly wheel, what kind of power can I expect at the wheels?
Also for the fuel system, would 42lb injectors do good?
I found it on another forum, and a few people said that they had problems with them. They said that they seemed to have problems with the pistons side loading.
and 400 at the wheels isnt unrealistic
