rear tire is wobbling and grinding
Old 02-03-2007, 03:49 PM
89GT5.0
89GT5.0's Avatar
Default rear tire is wobbling and grinding
My right rear tire is making a grinding noise and my friend was driving behind me and said its wobbling. What could this be? An axle bearing? I thought it could just be my brakes grinding and my wheel is bent but i dunno.
89GT5.0 is offline
Old 02-03-2007, 03:54 PM
mattdel
mattdel's Avatar
Default RE: rear tire is wobbling and grinding
a brake grind would have been a squeal for a while before this, and a wheel doesn't just bend. you gotta hit something pretty hard to bend a rim, unless your runnin 35 series sidewalls, or something like that. its also hard for bearings to blow up like that, and cause it to wobble. control arms is where i would start looking. maybe you ripped a torque box.
or have you done anything that required the wheel to come off? maybe the lug nuts aren't tight, or the wheel isn't fully flush with the drum. that would cause a brake grind and wobble.
mattdel is offline
Old 02-03-2007, 03:56 PM
w8less
w8less's Avatar
have u checked to see if some of the lug nuts have come loose? sometimes its the obvious things
w8less is offline
Old 02-03-2007, 04:05 PM
89GT5.0
89GT5.0's Avatar
Yea its not the lugs...the brakes did squeal for a while before the grinding started. It sounds like it only grinds on every other or third rotation though and i can only hear it when im goin like 40. It gets worse when theres somebody in the passenger seat too.
89GT5.0 is offline
Old 02-03-2007, 04:07 PM
mattdel
mattdel's Avatar
i would definately check the brakes out.
as for the wobble, your gonna have to find it on your own. we can't see it, unless u wanna take a vid of it.
does anything else wobble or is it JUST that wheel?
mattdel is offline
Old 02-03-2007, 05:48 PM
89GT5.0
89GT5.0's Avatar
just that wheel...
[IMG]local://upfiles/36668/2FDD671A73A74F299C4CA188DCE4D305.jpg[/IMG]
89GT5.0 is offline
Old 02-03-2007, 05:50 PM
93 LX FiveO
93 LX FiveO's Avatar
bring the rim to a tire shop and have them throw it on a balancer... ask if you can watch and you will be able to tell easy if the rim is bent
if it spins smooth, cancel out the rim.
93 LX FiveO is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
sorry, pic is no help. jack up the car and shake it down. best way to find it.
PRO50SC is offline
Old 02-03-2007, 05:51 PM
mattdel
mattdel's Avatar
its definately lug nuts or brake drum related. unless your did something to an axle, which i doubt.
mattdel is offline
Old 02-03-2007, 05:56 PM
89GT5.0
89GT5.0's Avatar
yea i know i just uploaded a pic so i would have it on here...
89GT5.0 is offline
Quick Reply: rear tire is wobbling and grinding
