xcam??
RE: xcam??
the x cam is not a split grind, so it will not sound as good as the trickflow one, also, the trickflow will make more power, that x cam has too much lift for a stock 302, how ever if you bough and installed already, just use 1.6 roller lifters, your power band will be in the upper rpm's
RE: xcam??
sorry yeah i do have 1.6rockers 70mm and tbdy 24lbs injectors with headers,Trick flow track heat package.... going with the xcam cuz i had the stage 1 trickflow and a lifter busted and wiped it out so i thought i would go bigger
RE: xcam??
MY DEAR FRIEND, TRICKFLOW MADE 350 HORSEPOWER WITH YOURSETUP using the stage one, however if you do bigger, just use the 1.6 rollers, going bigger may actually help try it out.[8D] and let me know, if you need any tips on the instal I have info down to the bare frame of your car
if you use 1.7 rr the valves will say high five to the pistons ,[:'(]
