pulled codes...or tried to...someone help ?
RE: pulled codes...or tried to...someone help ?
adder....just found some codes....can you explain what they all mean because i have not one dern clue...this is what i got so tell me if its the same thing....
O—Key On, Engine Off code.
CM—Continuous Memory code.
R—Engine Running code.
13 - RPM Not Within Self Test Lower Limit (R), DC Motor Did Not Move (O,CM,R), Idle Speed Control motor or Air Bypass
15 - Readout Memory Test Failed (O), Keep Alive Memory Test Failed (CM)
23 - Throttle Position Sensor Out Of Self Test Range (O,CM,R)
33 - EGR Valve Opening Not Detected (CM,R)
55 - Key Power Check (R)
67 - Park Neutral Position Switch Circuit Open; A/C On -Manual (O), Manual Lever Position Sensor Out Of Range/A/C On (CM,O), Clutch Switch Circuit Failure (CM)
ALL of this is greek...so PUH-LEEZE help a honky out man
judging by the looks of the codes, i would assume your ISC is either no good, or unplugged... I would however have to test your car to be sure
as for the code 33... check the vac lines that go to your EGR.. one might be cracked
ORIGINAL: JH23
what is a ISC and where would it be located ?...sorry for all the questions man...but with this i have no clue
its the long cylindrical looking thing on your throttle body. It should have two wires connected to it by one plug
