FYI - Cold Starting
RE: FYI - Cold Starting
You guys with "hanging" rpms: Like pro said, it could be the IAC. But, before you take it off inspect your throttle cable. I have this issue with my car and the throttle cable is binding up (I removed and cleaned the entire TB before I found the problem). There's a guide around the cable that wears at an angle, and causes it to stick. If you disconnect it from the TB and move it with your hand you can feel the "stick" in it.
New one is about $100 at the dealer only...
ORIGINAL: 93stallion302
ok lemme ask this if my rpms hang wen i start the car and wen i revv it should try 2 clean my IAC?might be stupid question but that rpm hang is annoyin
ORIGINAL: 90Lxstanger
Is that stock intake? or what
09-01-2015 08:16 PM
