90mm maf?
90mm maf?
i have a 92 5.0 sc im getting it tuned in the spring the tuner said i should get 42 lb injectors and a 90mm maf, i picked a 90mm maf of a lightning do i need an adapter to put it on to my application and if so where could i pick on up
RE: 90mm maf?
Yeah, you won't be able to install the LMAF or 42's until the car is at the dyno shop...
Here is a list of sources for various MAF adapters/harnesses...
(I think I found my 90mm LMAF adapter at ModularDepot)
Here is a Stangnet.com thread on fitting the sn95 MAF on a Fox Mustang.
http://forums.stangnet.com/showthread.php?t=616246
Here is a source for the 70mm Adapter Flange needed for a Fox.
http://www.kustomz.com/
This site has some dyno testing for a couple of common MAF setups…
http://www.secondstreetspeed.com/art.../mass_heir.htm
Photo comparison of a few MAF meters…
http://www.veryuseful.com/mustang/te...ox-LMAF-94.jpg
Some MAF connectors and other plugs…
http://rjminjectiontech.com/?p=10
MAF Adapters and Harnesses
http://www.blueovalchips.com/mafadapter.php
90mm MAF and Adapter
http://www.modulardepot.com/advanced...words=90mm+maf
http://teamjdm.com/shop/advanced_sea...words=90mm+maf
Here is their 90mm MAF Adapter
http://www.teamjdm.com/shop/product_...products_id=18
90mm MAF and Adapter / How to
http://www.lasotaracing.com/Late%20model%20maf.html
Some other various MAF Adapters
http://www.kustomz.com/cat3.html
RE: 90mm maf?
i got my maf and harness from blue oval and adapter at modular depotusing c and l 4 inch rubber couplers to connect maf to k and n cold air intake where i hacked off the end where the stock maf would bolt up too, with a rubber adapter around the 3 and quarter inch k and n plastic tube so 4 inch coupler can clamp down on it. got cold air intake with the car so i didnt have to spend money on something i had to hack up.
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
