500$ what should I spend it on?
RE: 500$ what should I spend it on?
get subframes, you can get full length ones from blue oval industries that come with the seat supports and torque box reinforcements for 120 shipped plus probaly about another 150 to get welded on.
i bought the chromoly upper and lower control arms and they look awsome, they also weigh 15 lbs less than the cheap ones on ebay and in summit, the only downside to them is i had to spend another $35 for the bolts for them( thought i could cheat and get them elsewhere and coudnt, and didnt want to take the chance with hardware stored bolts) you can get theupr full length subframe connectors for like $120 and they are the biggest that i could find and supposedly the strongest, they fit up pretty nicely but havnt got them welded in yet or the car running so idk about the control arms yet either but i did buy the hard poly upper axle bushing to go with them wheni ordered them.
Buy bolt on ones now if you want, then get them welded in later. I guess the bolts will come loose after a while and I hear that they are a pain in the *** to drill....either way,it is better than none.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
