fuel and power
fuel and power
what is a good RWHP to be at when switching fuel pump, rails and injectors to the next size up from stock? is it ok if i use a bigger fuel pump now with only about 235 theoretical RWHP. i also want to get bigger rails now, would it hurt to get them bigger when not running any high numbers?
RE: fuel and power
you should save the money for heads..... those stock injectors, fuel rales etc... will run 300rwhp.... now fuel pump you can use aftermarket, make sure to use a fuel pressure regulator.... bbk or something... with those mod's listed on your site i'd say your over 235.... closer to 250is easly...
uberstang1
09-20-2015 06:42 PM
