car shakes like crazy!!
RE: car shakes like crazy!!
correct me if i am wrong but if you jack up the car and you move your tires up and down is there is movement then more than likely its your wheel bearings. if you move it side to side and there is movement more than likely its your tie rod ends or maybe your rack. i have always heard this so like i said correct me if i am wrong.
ORIGINAL: new2v8s
i just got over the same problem persay but what happened with mine was i had bad vibrations from what i thought was the alignment but even though the tires were out of alignment and i got them fixed it still didnt help the vibration. come to find out my drive shaft was only hanging on by 1 bolt the others had backed themselves out and i had bent the weight on the rear end where the pinion is. so the fix was tighten the driveshaft and took the useless weight off and now its runnin like its on clouds
ORIGINAL: cassimus
note: my vibration felt like it was coming from the front also and i was getting tire wear in the inner parts of my tires
