bigest ci
RE: bigest ci
any things possable but if you cant awnser that question your self them dont attempt a swap. your dad will beat your *** if you had a 460 setting around the house for the next 4 years. also take in mind that a 460 weighs damn close to 1000 lbs, your suspensions gona have to be upgraded to, so will your brakes, and your gona need a new trans, once you get all that done your rear is gona break.
lets put it this way, ill ship the motor to you for free if you send me a video tape of you changing the timing chain on your car with out any help what so ever.
RE: bigest ci
that jegs motor is a joke. what a rip off. my buddy is building a 466 right now. the total for the hole motor including machine work will be well under $1500. should make about 450-500rwhp n/a and hes going to throw a 175 shot on it.
a 460 block will fit in the a fox body with little work. go to 460ford.com and youll see tons of them. an aftermarked 460 block can be bored and stroked to 806ci. the block and stroker kit are expensive but its possible
RE: bigest ci
ORIGINAL: samseed101
It doesn't quite answer your question, but this guy I linked to here put a 1100 cubic inch engine from a WWII Sherman Tank into his Mustang. 500 HP and 1050 TQ, LoL.
RE: bigest ci
460 block. but you can stoke it to 557 http://coasthigh.com/Assemblies/Ford/ford_557.htm
RE: bigest ci
i also found 2 good ones on www.powerdbyford.com for cheep idk if i should put thoes in insted
Jpope417
07-22-2008 01:45 PM
