cam questions!
RE: cam questions!
If you already have the B303 cam.....don't "upgrade" to the X303...both cams are similar, with the only difference on the valve lift. Valve events @.050" are exactly the same....if you still want to install it, just make sure you set the base idle correctly, any failure codes are fixed...and it should work fine.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
