suspention and springs
02-07-2007, 04:22 AM
can i cut my springs to lower my car if so how do i do it right?
02-07-2007, 04:29 AM
RE: suspention and springs
u can but it affects ride quaility
02-07-2007, 04:32 AM
by how much like what will happen
02-07-2007, 04:43 AM
if the springs are linear or you cut dead coils it shouldnt change the ride much at all, unless you go overboard.
02-07-2007, 04:46 AM
ok so i want a inch and a half drop i can cut my stock ones right
02-07-2007, 04:48 AM
u can. cut a about a coil and let it seat it should be close enough to what u want. ur ride quality shouldn't suffer much
02-07-2007, 04:52 AM
so thats a cheap inexpensive way to lower the car so one coil is about 1.5 inches
02-07-2007, 04:57 AM
02-07-2007, 05:02 AM
give or take. u can also heat the springs up and let the weight of the car compress them
02-07-2007, 10:08 AM
I would rather see you cut a spring down than do this.
When you heat the metal in your springs, you're helping to fatique them. This is a dangerous method.
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Gene K
10-21-2015 11:37 PM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
