CHEAP MODS!!!
RE: CHEAP MODS!!!
dont go with 4.10s on a 5 speed, i have 3.73s and thats all you need. at 65mph i run about 2300rpm and top out at about 130mph. and i adjusted my timing to 15 and didnt feal a thing. (and yeah the spout was out)
RE: CHEAP MODS!!!
How do you guys wth otherwise stock cars get 'em to hook with 3.73's? I can't nail down with 2.73's.
In my short time with a 5.0 I'd recommend building suspension and chassy long before more power or gear. Use what ya got.
$.02
$.02
RE: CHEAP MODS!!!
ORIGINAL: stupidaso06
How far should i adjust my timing for not having to run premium?
RE: CHEAP MODS!!!
ORIGINAL: buget94gt
if you just ease into it you shouldnt have a problem. and it helps to have some good tires.
Point remains that chassy and suspension will make the entire car, and it's existing equipment, work better. That's the direction I've chosen with mine and I hope it pans out.
RE: CHEAP MODS!!!
My car has literally gone sideways about a foot in 3rd at around 60. I totally agree that in my case the tires are a huge problem, but I'm still starting at the bottom and going up. Before DR's I gotta do battle boxes, torque arms, etc, etc...
So, my proposed list of cheap mods:
Better brakes ($150, summt cross drilled rotors, some ceramic pads, clean and lube the rear)
Springs ($200, I like my FRPPs, choose what you like)
Subs ($120 + welding, hard to beat Maximum Motorsports for the price)
Battle Boxes ($100 + welding, quality set)
Torque arms ($200, entry level, much better than OE set)
Gears ($300 cheap Jegs ($450 for richmond) gears w/master kit + install: or requires some skill)
All of those are, more or less, one or two pay check type of deals for most guys except the gears...
