Please help me because I am lazy and don't want to RTFM
Old 02-08-2007, 03:36 PM
88BlueGT
88BlueGT's Avatar
Default RE: Please help me because I am lazy and don't want to RTFM
ORIGINAL: frdmstng1986GT
ORIGINAL: samseed101
ORIGINAL: 88BlueGT
So its only aluminum intakes that need to be torqued down in a specific bolt pattern?
Is there a pattern for Iron too? I know that the lower has a pattern, but I wasn't sure about the upper. I added a 1" spacer so I never had to remove the lower.
all intakes, cast iron or aluminum or... sheet metal if you are a ricer()... have bolt patterns. it prevents from minor warping and chances for leaky intake gastkets.. .. usualy it is just work from the middle out in a circle.
I hope that was a joke right?
88BlueGT is offline
Old 02-08-2007, 05:19 PM
LTnone
LTnone's Avatar
Every intake, whether made out of aluminum, iron, or grandma's two week old beef stroganov, requires a pattern tightening. If you clamp one end all of the way down, and continue toward the other end until finally the other end is done last, it won't clamp down as much. Same principle as the star pattern on a 5 lug. There is also the risk, in certain applications, of pushing the gasket around. The same goes for heads, etc.
Don't take this for law because it's an aluminum intake, but this is probably the sequence you're looking for. I'll leave specs alone because they will be different for iron. Don't forget to coat the bolts in 30w motor oil (which will probably also change specs)
LTnone is offline
Old 02-08-2007, 06:20 PM
frdmstng1986GT
frdmstng1986GT's Avatar
ORIGINAL: 88BlueGT
ORIGINAL: 88BlueGT
yes i was...... hence the wink.
frdmstng1986GT is offline
Old 02-08-2007, 06:27 PM
samseed101
samseed101's Avatar
ORIGINAL: LTnone
I agree that that is a very helpful image. However, i know the pattern for the lower. I need the upper manifold pattern
samseed101 is offline
Old 02-08-2007, 06:53 PM
LTnone
LTnone's Avatar
I suck...
If I were to guess, middle two, one side, then the other. But once again that's guessing. Haven't put mine on yet. It struck me odd that someone like you would ask that question
LTnone is offline
Old 02-08-2007, 06:56 PM
samseed101
samseed101's Avatar
ORIGINAL: LTnone
I suck...
LoL, yeah, info about the lower seems common, but the upper seems to be ignored. I'm just gonna work from the middle out and first hit 6, then hit 11 or so foot pounds.
I like your setup BTW. Curious what kinda nuymbers you are gonna pull when it's all said and done. I was soooo clsoe to going to the trick flow top end kit, but wussed out in the end [8D]
10-07-2015 07:02 PM
firecoyote
09-27-2015 02:37 PM
2015Ecoboost
09-17-2015 01:48 PM
Roush05
09-10-2015 12:23 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Please help me because I am lazy and don't want to RTFM
