egr simulators and trouble codes
RE: egr simulators and trouble codes
If you are deleting the EGR.....yep, it works....it will only cause a code 33 KOER or KOEO/CM to show up but the CEL will not be triggered.....which codes are showing up?....
koeo- 91-41-34-85-67
91-41 are o2 codes
67-nuetral drive switch
one is a canister purge code and the othr is an egr switch code
koer 12-21-41-91-34
i replaced the egr swich but havent checked the comp since then i have ne wo2 sensors butim not gonna put them in til i build my new motor
91-41 are o2 codes
koer 12-21-41-91-34
ORIGINAL: stupidaso06
how do i just delete my egr valve? can i just unplug it?
^^ that is not true...
im showing codes 33,94,44 all EGR/AIR related
CEL flashes like crazy when the car is warm and running at a set RPM for long periods of time.
i Solus scan the car daily...
ORIGINAL: 93 LX FiveO
