need help picking afr heads?
ok im looking for a set of afr heads for my 91. its just going to be a street car its my daily driver so. im stuck on the cc options. there are 58cc 60cc...... just curious what would be best. o and i plan on s/c it later if that helps?
RE: need help picking afr heads?
i run the 58cc chambered heads with boost and no problems. the 58cc heads only get you to about 9.5:1 which isnt high for boost anyways. i was running 10psi of boost. my new motor will be 10:1 with boost.
If my memory serves the 58 and 60cc heads are different rocker mount types, so it depends if you're gonna run your stock pedestal mount rockers or not. If you are then you need the 60cc chamber b/c the 58 and 61cc heads are for stud mount.
ORIGINAL: OnyxCobra
58CC and you better get the VP clearance checked when installing the heads. You don't want to assume anything will fit without problems and definitely don't want to learn the hard way.
KingRando
10-02-2015 08:06 AM
