has anyone had a block diped?
RE: has anyone had a block diped?
General block machining (overbore, this and that), cleaning, cam bearings/installation, plugs, is usually around $400.
A tanked block pretty much looks like new when you get it back in terms of clean.
ORIGINAL: 2 kwik
that's only the beginning, all the passages(oil,water) need cleaned and all threads need cleaned up as well
as for cost between 55-85.00
not quite, I have seen some with crap still on them....this is why a GOOD machine shop will do 2-3 other type cleanings on the block
ORIGINAL: Maxwelhse
Totally possible my machine shop is above average. I write they check, they give me good work. The bill says "block cleaning" somewhere on there and they have a dip tank... Just assumed the two went together.
It's exactly the type of business arrangement that I like.
