THROW OUT BEARING
THROW OUT BEARING
I feel like a dummy....i am changing my clutches, now i am about to install the bellhousing, but when i went to put the throwout bearing on the fork...i drew a blank on how it goes on....any help would be greatly appreciated!
RE: THROW OUT BEARING
yea....i just can't remember if the lip of the throwout bearing goes in between the fork and the 2 clips, or if it rides on top of it.....if that describes it good enough....plus the bearing is pointed at one end
Here you go, this was the best I could get so I hope it helps
[IMG]local://upfiles/25112/207D4232D6DE43FE9D6B45185F328767.jpg[/IMG]
[IMG]local://upfiles/25112/F4DBB08AC580475692B3929FF3E3ED5D.jpg[/IMG]
yeah i had a problem with mine when i put it back together my friend put it on backwards so after i got the trans up and all bolted in i went to step on the clutch and nothing it went right to the floor i was like wft and then i had to pull the trans again
