i need info on this MAF
i want to buy this maf sensor. my question is does it come with the little black upper spout connector or do i need to swap it from my stock unit to just the 73mm metal tube. if so, wouldnt that hurt the computer since the stock ones are calibrated to 550 CFM? if not, ignore this post.
thanks.
SENSOR: http://www.jdsperformance.com/index....tem&inmake=all
thanks.
RE: i need info on this MAF
yes you put your stock electronics back on it..every thing else bolts right up..I would however save your $$ and buy a used one as these things don't where out..just make sure you get the right sample tube for your injector size
its not the electronics that are calibrated for 19# injectors, its the maf housing. using your stock electronics wont hurt anything. i have the 76mm maf from c&l and it works fine. there is a small tube in there that calibrates for the size injectors. when you get larger injector, you change the tube on the inside
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
